Black Magic Fan install...
RE: Black Magic Fan install...
Does it matter that the gauge of the wire is soo thick? I mean it wont be blowing fuses when it turns on right?
Should I route it to an external switch or to my key switch?
OK im preety much done, installtion was easy. Only problem I ran into was the fan being soo close to the Crank pulley, I wasnt able to use the brackets in the kit.
Just need to wire it up to 12 volt switched source in the car and it will be done, I tryed it out already and it work great.
Heres pics. For you stanglx
[IMG]local://upfiles/15818/73825B98C7174F60BE7792D0C1AD1356.jpg[/IMG]
[IMG]local://upfiles/15818/8377D77F96E64DC696A981E149C85F08.jpg[/IMG]
i like that fan thats the one i have, ilive in el paso and it works great. I KNOW el paso gets hotter than houston. I would check other things on your car before you start wanting to switch back to the loud a$$ clutch fan.
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
