Next mod
Next mod
What would you do next besides heads/cam with this set up. 5 psi Vortech SC, 1 5/8 headers, 3 inch custom mandrel bent exhaust with Borla mufflers, 73MM MAF, 70 MM TB & EGR, MSD 6 AL ignition, MSD blaster coil, TF Street intake, 355 gears, Black Magic Xtreme electric fan, Fluidyne aluminum rad, short throw shifter, 160 stat, pulleys, 30 lb. inj., custom tune, Koni shocks/struts, Kenny Brown subframe connectors, strut tower brace, caster/cambor plates, etc.
RE: Next mod
I've been told the stat isn't right and I also have a 190 lph FP, boost, AEM wideband air fuel gauge, a Mallory AFPR, and a rail mounted FP gauge.
I was thinking of getting a smaller SC pulley already and wondered what kind of control arms you'd recommend.
RE: Next mod
I'd swap that out to a 180*. As for control arms, depends on what you want out of it. Do you just want to improve from stock or do you want adjustability? If you like straigh tline performance, you can go with adjustable lowers and uppers. The adjustable upper will allow you to set your pinion angle for more/less hit to the tires on launch. D&D has some good products as does Baseline Suspension. Pro3i has some nice units as well. If your going to go the control arm route, I would also suggest some torque box reinforcements to go along with them.
