Ok should i get a trick flow upper and lower intake? OR 30lb. injectors with a calibrated mass air, 255lph fuel pump, and a 75mm throttle body. or do you have any other ideas
Also make sure that the trickflow intake you are going to get has a 75mm+ inlet opening to match your 75mm T-body. If you don't have a inlet opening thats as big or bigger than your T-body then you're going to have airflow issues.
