PISSED!!
#21
RE: PISSED!!
when i first read it i thought damn, a 10 sec sixxer, assuming you meant the 1/4. then realized that you meant the 1/8. but he man shyt happens, atleast it wasnt like you cant drive for shyt, or your car sucks, just a stupid floor mat in the way, go uot next weekend and show em whats up.
#24
RE: PISSED!!
ORIGINAL: 92GreyGT
I read the entire post and yeah I'm sure the floor mat didn't help but it's not 2" thick. 471 horsepower at the rear wheels he should be way in the 7s.
#25
RE: PISSED!!
I agree with you 100%, if you have a blower or spray it would affect you more not having WOT. If he has spray I didn't see it. Even with the floor mat under the pedal I just can't see it slowing him down 3 seconds in the eighth.
#27
RE: PISSED!!
ORIGINAL: 92GreyGT
#30
RE: PISSED!!
that dyno is at the the fly , had the motor dyno befor it was put in , Had a bad rocker arm on the dyno so i think it should be a little more , i have a 2500 stall wich is killing my moto on take off unless i have spray and if i dont get wot on take off u can hang it up, i do need a good tune but dont have the money right now , and who ever raised the bs flag needs to read the post. Hears my mods , 302 ci bored 40 over converted to carb; 10.5:1 total compression ratio; stock crank fully balanced; scat rods; hyperutectic pistons; comp cams XE274HR cam .555/.565 lift; 1.6 roller rockers by Scorpion; valve train stud girdle; ford racing polished valve covers; victor jr intake with 1" phenolic spacer; holly 650 CFM double pumper; procomp aluminum heads (ported and polished) with 2.055I, 1.60E valves. It also comes with MSD probillit distributor, MSD 8.5 mm wires, MSD blaster 2 coil, MSD digital 6 plus ignition system, stainless steel braided fuel line, holly fuel pressure regulator, fuel pressure guage, Pro-form electric fan, and 160 amp alternator
[IMG]local://upfiles/43346/1669167EC979443291D36C0D006F6AC1.jpg[/IMG]
