New car to maintain.
Old 07-28-2004, 11:33 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Default New car to maintain.
As you all know I just bought my first mustang. 91 LX dark green (bite me roundman ).
The car has over 135k miles and all i want to do is pep it up. I dont want to mod it just yet, can someone please tell me what i can do with garage tools and lots of time to tweak the engine. All i need is advice on how to clean injectors, how to identify parts of the engine (not the obvious ones) how to set timing, how to remove the smog pump (and what is that thing for anyway), what to do and what not to do when maintaining etc..
So far i changed the powersteering fluid and will be changing oil soon. Is there anything else i can do to this tired engine to bring its pep back up? Any advice will be helpful.
Thanks people.
Dbeck002 is offline
Old 07-29-2004, 12:05 AM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Default RE: New car to maintain.
Also,
Is there anything really important I need to know before I start f-cking around with mods? I want the engine to be as healthy as possible. TIA.
Dbeck002 is offline
Old 07-29-2004, 12:12 AM
mkspeed26
mkspeed26's Avatar
do a full tune-up. ie plugs, wires, cap, rotor, oil change, radiator flush, new air filter (might as well go with k&n), new fuel filter, check ur brake pads, and get some lucas fuel injector/system cleaner. that should give it some more pep.
mkspeed26 is offline
Old 07-29-2004, 12:24 AM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Can I do this by myself? All of what you mentioned? I don't want anyone touching my baby.
Dbeck002 is offline
Old 07-29-2004, 12:25 AM
Duffs302
Duffs302's Avatar
I have started to use Shell's new V-Power prem. fuel for the past month. That peped the eng.(w/ 153K miles) up some. Restore didn't work.
Duffs302 is offline
Old 07-29-2004, 12:27 AM
mkspeed26
mkspeed26's Avatar
you can easily do that urself. if you need help, give me a pm
Old 07-29-2004, 02:23 PM
roundman
roundman's Avatar
BITE![sm=lol.gif]
Don't remove the smog pump if you have to pass any emissions testing or you will flunk the visual part of the test. In addition to changing the engine oil, you probably should also change the tranny oil and the rear end gear oil and examine both used oils for signs of metal debris or other contaminants. while you've got the cover off the rear, you can inspect the ring and pinion gear and also count the teeth of each so you can determine the gear ratio. when you put new oil in the rear, you need to get a 4 oz bottle of Ford fricition modifer for the Traction Lok differential clutches and add this with the new oil. you might also want to inspect all the front and rear suspension parts for worn bushings, loose nuts and bolts, etc and see if anything looks bent. check to make sure the struts and shocks are not leaking too while you're under there.
BTW you will need to invest in some metric wrenches and sockets as there are a lot of metric fasteners used on the Stang too. get good ones like Craftsman who give a lifetime warranty.
And I will stop ragging you about the color of your Stang! Different strokes for different folks I guess!
roundman is offline
Old 07-29-2004, 02:35 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Hahaha, thanks for the info. I'm gonna go to the autoparts store and get some components.
P.S My engine misfires when I rev it up slightly. I don't know what is the cause and I dont know how to check timing lol. I suspect its the distributor rotor or cap. Any other possibilities? My dad is going ape sh-t, he thinks the computer is all messed up. Could it be that?
Dbeck002 is offline
Old 07-29-2004, 02:43 PM
roundman
roundman's Avatar
Try installing the new distributor cap and rotor first and see if the miss goes away. New plugs may also get rid of it too. and lastly new wires if the other stuff doesn't cure the problem. I don't think it is a bad computer, probably an ignition or fuel problem. Fix the ignition system first and then see from there. also get a small tube of dielectric grease at the parts store and put a small dab inside the spark plug wire boots when you install the new plugs. this helps keep moisture out which can cause misfires. some on the distributor ends of the wires wouldn't hurt either. don't jerk the plug wires when you take them off, twist them to get them loose from the plugs first then pull slowly to remove them so you don't break the internal conductors inside the wires. a broken wire won't necessarily show up from the outside and this could definitely be a source for misfiring. you will need a timing light to set the timing properly.
roundman is offline
Old 07-29-2004, 08:37 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Thanks ROUNDMAN! I will investigate my spark plugs tonite!!! BTW I NAMED MY CAR SHEILA.
Dbeck002 is offline
Quick Reply: New car to maintain.
