A/C & Smog delete now running rough? HELP!!
Hi, i just did the a/c and smog delete 2day and just got back from doin a lil test drive. I did all the normal install things, but i also used a powerwasher to clean some grease and stuff i had built up(bad valve cover gaskets). When i first started it up it sounded fine ran good all that but after like 5 miles if i would hit the gas it would bog down or get real jerky, WOT is useless does nothing but jerk. Another thing i mite add is that the car never did start right, i would always have to crank it for a while b4 it would start to fire(maybe fuel pump?). Any help or suggestions i would really appreciate Jon
RE: A/C & Smog delete now running rough? HELP!!
ah thanks for that tip gonna go try it now, i was also thinking about the timing i tried to move the distributor but it wouldnt budge anyway it could have moved?
Mannnnnnn thanks alot pro50 opened that up tons of water.... didnt even think about that at all [&:] gonna go for another testdrive think that did the trick tho THANKS!!
musnicki
09-23-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
