My next mod(s)?
RE: My next mod(s)?
My suspension is pretty tight right now as it is with the new springs and control arms. I kinda like to touch one area a little bit at a time like I've done so far, got all of the motor mods done first, then I did the gears, then the tranny, then suspension, and now I think I need a little more heat under the hood. Plus a blower just sounds bad ***.
RE: My next mod(s)?
If I was to do heads and a cam I would also need to get a manual valve body because the cam (unless there's a decent one that redlines at 5200 rpms) would change my shiftpoints.
RE: My next mod(s)?
Do the heads and cam before the supercharger. Id stick with a Trickflow Cam and the matching Trickflow Heads. They make great power. They will also help you out if you eventually get a supercharger for your car. As for what kind of supercharger...Id go all out and get the Kenne Bell. Awsome low end power and torque. You wint need a tall gear to get you into the powerband like a vortech or procharger would need.
