Help! pulley install
Old Oct 14, 2006 | 01:09 PM
loeryder21's Avatar
loeryder21
Default Help! pulley install
im installing a set of mac underdrive pulleys and i cant get the old pulleys to come off its an 86 5.0. any ideas or advise? thanks
Old Oct 14, 2006 | 02:32 PM
Stanpower's Avatar
Stanpower
Default RE: Help! pulley install
I think you need a special pulley for that...........
Old Oct 14, 2006 | 02:58 PM
AdderMk2's Avatar
AdderMk2
Banned
shouldnt be that hard. the pullies you need to remove (aside from the alternatoer pulley) are only head on by 4 screws each... i believe the crank pully bolts are 14mm, however i forget what the water pump ones are... 10mm maybe
Old Oct 14, 2006 | 03:04 PM
loeryder21's Avatar
loeryder21
i already got the crank pulley and the fan pulley off the alternator is bein a bitch i cant stop it from spinning and i dont want to damage the fan
Old Oct 14, 2006 | 03:33 PM
AdderMk2's Avatar
AdderMk2
Banned
well my advise to you would be to leave the alternator pulley on there, its really not making you lost any mower, and when you spin the alt slower, it will not charger your battery as well. most of us have problems with out UDP's and the alternator not producing any power at idle. Thats why im taking mine off soon.
Old Oct 14, 2006 | 03:48 PM
marx91's Avatar
marx91
your going to have to take the alt. off and have a garage bump that bolt off w/ the air wrench
Old Oct 14, 2006 | 03:52 PM
5IVE.OH's Avatar
5IVE.OH
It's simple to do. Just jam the pointy end of your prybar inbetween the fan blades and turn the nut off..
Old Oct 14, 2006 | 04:32 PM
85 Stang's Avatar
85 Stang
Try taking it to a autoparts store mine did it for me. All they did was took a drill with a socket and it came right off.
Old Oct 14, 2006 | 05:57 PM
89gtsleeper's Avatar
89gtsleeper
Yeah, if you are running a 5.0 stock alternator. I would not put the underdrive on it.
mtgldr
Feb 3, 2024 09:00 PM
Jb145700
Aug 21, 2022 06:37 AM
OSUTX440
Ohio Regional Chapter
Mar 15, 2021 09:27 AM
spdeplayer2
Oct 24, 2015 09:45 AM
ctgreddy
Sep 20, 2015 08:35 PM
