Clutch install....failed :(
#21
RE: Clutch install....failed :(
Use penetrating oil....the torch will heat up the bolt and expand it. Also, the red loctite isn't superglue...I've used it on my DS bolts and had to remove them w/o too much effort. Make sure your tranny is in gear and your parking brake is on, that will keep anything from moving when you crank on it....
#23
ORIGINAL: black89gt
fit the breaker bar on teh bolt? im talking about a pipe dude.. ahah get a pipe that will fit teh wrench and use the leverage. the more leverage the easier it is for the bolt to come loose. trust me.. i work at my dad's transmission shop.. we gotta do it all the time.. ahha
ORIGINAL: gspfunk
#24
Huh? You don't heat up the bolt, you heat up the flange, you never put the flame on the bolt. Sure the bolt will expand some, but the flange expands more, also burns the loctite inside if there is any
#25
internal corrosion may be at hand here. ive seen mechanincs not give a dam and just use a impact, making the worse senario later.
keep that torch on her for 60 seconds each bolt, it will come out, if not drop the whole thing, MOTOR MOUNTS !, dam your in my bolts hear, PB blaster overnight and torch, and boy they will fight
#27
Okay, so I've put together this list of things to get those damn bolts out:
1) Oxy-acetylene on the flange
2) Bigger impact wrench
3) Long *** pipe
4) Lots of penetrating oil over the next 2 weeks until I try again.
Any more suggestions?
3) Long *** pipe
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
