motor mounts?
Old Oct 18, 2006 | 11:58 AM
88lx5.0's Avatar
88lx5.0
Default motor mounts?
my motor mount is on its way out how hard of a job is it to install. im going to have to pull the motor right?
Old Oct 18, 2006 | 12:40 PM
4fit?'s Avatar
4fit?
Default RE: motor mounts?
No. Just jack the motor up. If your going to replace them, do it right and use polyurethane mounts. Be a good time to do your tranny mount too.
Old Oct 18, 2006 | 12:45 PM
Archion's Avatar
Archion
+1 not very hard with basic tech skills, if you do go urethane, you will have to get trans mount to do it properly.
Old Oct 18, 2006 | 01:08 PM
7upedition's Avatar
7upedition
might as well replace motor and trans together, get a matching set for all three... just unbolt, jack up under oil pan, and replace mounts, lower in and bolt back in place...
fastfox86's Avatar
fastfox86
Energy Suspension has a poly kit with engine mounts and trans mount. It's pretty easy to do. Just take the motor mount nut off each mount and jack the engine up by the oil pan. BE SURE to use a wooden board between the oil pan and jack to spread the weight of the engine out evenly or you will kill your pan.
Old Oct 18, 2006 | 03:32 PM
blybdas's Avatar
blybdas
Not hard. I went with solid mounts when the stock rubber got weak. Took about 2 hours to do both motor mounts and the tranny. Didn't get as much vibration or noise from the solids as most would think, but definate difference in hard launches. Make sure and loosen both mounts before you jack the motor up. +1 on remembering to put the wood between the jack and oil pan.
Old Oct 18, 2006 | 04:30 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: 4fit?
will those give you more vibrations in the car? I'm gonna do my mounts when the engine is out but i dont want my car to shake and buzz and stuff b/c of stiffer mounts...
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
