long headers on 94 a waste
RE: long headers on 94 a waste
this has been debated for a long time... some say it wont hurt and gears will make up for it, some say low end torque is terrible, dyno and manufacturers recommend LT's for high hp app's with lots of torque.... figures vary but unless your well over 300 i wouldn't put them on, but its jmo
i should have 330 to the wheels but the car is not running right and the tuning shop is having a hard time tuning it for me with all these mods done to it . they said the cam in the are is to big i have the track heat cam form trick flow .
i bought a 302 bored over.040 to a 308 9.8:1 it has :
all forged interenals piston, i beams, rods.
- heads specs -
trick flow twisted wedged heads #51400002
61 cc combustion chamber
2.02 intake valve
1.60 exhaust valve
high rate valve spring 7,degrees lock manganese broze guides.
trick flow 1.6 roller rockers
--cam specs --
brand new trick flow track heat cam # 51402000
lift : 499 in intake / .510 in exhaust
duration : 275 intake / 2.79 exhaust
lobe separation : 112 degress
--add on to the engine--
cobra upper and lower intake manifold
bbk long tube headers
70mm throttle body edelbrock
75mm mass air pro-m
30lb injectors calibratred
255 fuel pump
bbk fuel pressure regualtor
i cant get it running right it has bad idle the air /fuel mixture is off and it dies out when coming to a stop .
- heads specs -
2.02 intake valve
1.60 exhaust valve
--cam specs --
75mm mass air pro-m
255 fuel pump
i would think you gettin enough to those lts to make them worth while... you just at the bottom u got tons of room to add hp be thet headers limit u... i have a 95 cobra with 75 bbk tb 76c&l maf and mac lts mac prochamber and mac underdrive pulleys... so u got more than me... nitrous is coming soon for me tho... im think a 125 shot so what will also help oh yea and gears and catbak should be done within the year
junior04
09-28-2015 10:53 AM
