E-303 vs Trick Flow Stage 1 cam..opinions
Old Oct 21, 2006 | 10:21 PM
SteveSkal's Avatar
SteveSkal
Default E-303 vs Trick Flow Stage 1 cam..opinions
I wanted to see what your opinions of the Trick Flow cam as to the E-303. I currently have the E-303 in my car. Will the Trick Flow make more power, and also even though its not touted as an Emissions Legal cam, do you think it will blow clean enough to pass a sniffer test? I'm leaning towards a new cam when I swap in AFR165's this winter but I need to be able to pass emissions testing every other year, but I also want as much horepower as I can squeeze out
Old Oct 21, 2006 | 10:24 PM
Ninety5five0's Avatar
Ninety5five0
Default RE: E-303 vs Trick Flow Stage 1 cam..opinions
With those 2 i'd go with the trickflow just because its newer. I hear alot about the alphabet cams being outdated, and some say they are still perfectly fine. Which TONS of guys are making huge power on alphabet cams. I read some really good reviews about the stage 1 cam, thats why i went with it. I just dont know how it performs yet. Car is almost done, just not quite.
But if your going the AFR route, why dont you look into custom grind cams ? The only aspect there is that i'm not sure if custom grind cams are emmision legal or not.
You might even want to call crane or comp cams, they both ahve a huge selection of cams, and i'm sure one of their techs can tell you which on will make the best power for you. Or even call trickflow to see what they say.
Good luck. whatever you decide to go with, let us know how it turns out.
Old Oct 21, 2006 | 11:45 PM
XSRACINGGT's Avatar
XSRACINGGT
You should be about even on the power of either cam. They are about the same numbers wise. I would just put a set of 1.7 RR on your E cam and save the money instead of buying the trickflow. Just my opinion tho bro...
Old Oct 21, 2006 | 11:58 PM
OneFine89Mustang's Avatar
OneFine89Mustang
the trick flow is a updated and better cam
Old Oct 22, 2006 | 04:59 PM
mustang93's Avatar
mustang93
bump. i want to know some more too!!!
Old Oct 22, 2006 | 05:02 PM
FordMustangXBA's Avatar
FordMustangXBA
There really isn't that much of a difference...You can make huge power with alphabet cams too, whether they're old or not.
Old Oct 22, 2006 | 05:09 PM
mustang93's Avatar
mustang93
does anybody know the price difference between the two? and where can i find the stage one cam, i look on summit, and i dont konw what one it is b/c trickflow makes a bunch of them. any help guys?
Old Oct 22, 2006 | 05:33 PM
Ninety5five0
Its 159.95 from summit. Part # TFS-51402000
Old Oct 22, 2006 | 05:39 PM
ZachW04Stang's Avatar
ZachW04Stang
Your not going to see a very noticable difference swapping to a trick flow cam. Maybe 5 hp and a couple ft lbs of torque. Like stated above I would just get some 1.7 roller rocker and it would definitly increase your power more that way then swapping the cam.
Old Oct 22, 2006 | 05:44 PM
Ninety5five0
Duration is almost the same, and so is the lift. Very little difference. Since you already have the E cam, just keep it in there, the time and money wouldnt be worht it.
