Crate motor!
RE: Crate motor!
Come on now, it takes a little more to be a firefighter. It talks real ***** to be a firefighter. I was a tick as an EMT and I grew up in a family of firefighters. Medics and firefighters are awesome people.
RE: Crate motor!
It sounds to me the motor isnt your problem. It seems like if there was a problem with the motor then you would hear a knocking, or the engine would not run right when it is running. Sounds like maybe an electrical problem. I would go through all the other(cheaper) possibilites before you invest in a new motor. JMO
RE: Crate motor!
Anyways if you give up on the motor I will take it for some bills. Let me know my friend KillaE needs a motor and I am assure that your not in need of one. His car use to die but he replaced the IAC/Ignition Module/Stator and it did fix it.
logan409
09-26-2015 07:43 PM
