Removing those damn rear 12 pt bolts holding in the drive shaft!!!
Old Oct 25, 2006 | 07:33 PM
  #21
88blackgt's Avatar
88blackgt
Default RE: Removing those damn rear 12 pt bolts holding in the drive shaft!!!
the wd might light a little bit but its not going to like set the car on fire or be dangerous at all lol ive had plent of experience w/ lighting WD on fire
Old Oct 25, 2006 | 09:06 PM
  #22
fordboyyfm's Avatar
fordboyyfm
jeeeze, i used to pull transmisisons out all day long for a year and never ran into this problem, usually used a 12mm ratchest wrench to get them out. You guys must be pretty scrawny!! haha jk
Old Oct 25, 2006 | 09:08 PM
  #23
black89gt's Avatar
black89gt
i told you already man... get a 12mm wrench and a about a 3 -4 foot cheater pipe.. the car is going ot be on the lift obviously so.. just put it on there and push as hard as possible.... and make sure you haev your ebrake on
Old Oct 25, 2006 | 10:07 PM
  #24
88blackgt's Avatar
88blackgt
lol why is it going to "obviously" going to be on a lift? a minority of people have regular access to a lift
Old Oct 25, 2006 | 10:08 PM
  #25
VigCS's Avatar
VigCS
ORIGINAL: black89gt
I've already said I don't have access to a lift....
Old Oct 25, 2006 | 10:15 PM
  #26
macgyver's Avatar
macgyver
I've heard that you can use wax. Heat the bolt and drip wax on the back of the flange where the bolt comes through. The wax will work into it and free it up.
I haven't tried it, but a friend told me about it.
Old Oct 25, 2006 | 10:32 PM
  #27
tuff5liter's Avatar
tuff5liter
ORIGINAL: r.barn
put two wrenches togther, then laying on your back step on it.
you can get a LOT of torque into it when you are using your whole leg to push with.
+100000000000000000000000000
specially whenever you are a fat *** like me, just put your body weight behind it.......
its called "ooofin" the bolt out.
just oof it out. :-)
Old Oct 25, 2006 | 11:03 PM
  #28
86 5.0L's Avatar
86 5.0L
12pt wrench + 4 foot metal pipe extension = piece of cake, unless you guys are scrawny [&:] and all I used was a jack and lifted the driver side rear tire
Old Oct 25, 2006 | 11:05 PM
  #29
stangateurlilz06's Avatar
stangateurlilz06
i can't beleive this.. i seriously have NEVER had this problem.. i have always used just a 12mm box end wrench.. and hit it with my hand once or twice.. and wham its loose..
as for this situation.. if the car is going to be on jackstands.. use a 12mm socket, and rachet.. then use a jack handle or pipe on the end of the rachet.. and wham it should come loose..
sean
p.s. good luck
Old Oct 25, 2006 | 11:12 PM
  #30
fordboyyfm's Avatar
fordboyyfm
yeah common its not hard. Hell i did it laying in the burn out pit at MIR at a pinks taping!!! Spray some juice on it and let it sit over night and then put some *** into it.
