cylinder heads
RE: cylinder heads
oops...didnt see that.
Without the heads your missing out on some serious HP (obviously) Heads and cams are like peanut butter and jelly. They are okay by themselves but when you put them together....thats when the magic happens. haha
RE: cylinder heads
ORIGINAL: 2 kwik
add the heads and some 1.7 rockers to inprove flow no need for a cam yet something with a 1.90" valve will work great
RE: cylinder heads
ORIGINAL: Jasperstang308
ur losing out on potenial hp without the heads. and sam i bet ur car was a pain in the a$$ to tune with boost and nitrous
Well after pullnig my hear out of my *** I realzied that I still had my underdrive pulleys on, and they were causing the S/C pulley to turn less, thus causing less boost. So I had to swap out the three pulelys and then start all over again from square one now that I was getting the full 10 PSI I thought I had to begin with!
The nitrous was a little more forgiving, actually. Just make sure you get the right jet sizes so you're not too rich or lean and tweak it from there.
However, I am now going to do a complete H/C/I over the winter. That's gonna F everything up and that's gonna be a pain to tune..especialyl because of the cam [&:]
