e6's
well if u are goin to put on heads yes , the 87^ didnt need to be notched they came with better pistons, and i would suggest not notching ur pistons unless ur a mechanic b/c it requires taking them out of the block whihc means disassembliing the whole thing, which if u have it done cost over a 1000 and then nothing them is like 100
your best bet is to do what i m doin find a 87^ block and put heads on that, it will save money and time.
modified e6's?
Anybody seen.. or heard of anybody using these? i never heard of anybody modifying e6's before till i found these.
acutally no, b/c u have to take the whole motor out to disassemble it then it has to be take apart notcthed put back together than back in teh block it will cost u well over 2000 dollars just for that, as far as a motor, a stock 87^ block which will be all u need will run no more than 5-6 hundred i m gettin mine from a buddy for 300
