aod aode?
Old Nov 1, 2006 | 08:45 PM
scooterstang's Avatar
scooterstang
Default aod aode?
what is the difference in an aod and an aode transmission?
Old Nov 1, 2006 | 08:57 PM
samseed101's Avatar
samseed101
Default RE: aod aode?
ORIGINAL: scooterstang
The AODE tranny is electronically controlled (hence the E.) It also manually shifts slightly different. In an AOD, the OD is actually a "gear" you select with the shifter. But with the AODE it's a button that you push to either engage it or disengage it. Because of that, you can actually shift 1-2-D manually with an AODE, as opposed to 1-D-OD with an AOD. The AOD can be modified to have the same shift characteristics of the AODE, but that usually takes a new valvebody.
Old Nov 1, 2006 | 09:02 PM
1BIGMOFO's Avatar
1BIGMOFO
^ +1 , aod= fox's etc aode started in 1994
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
CarrieS
Sep 1, 2015 01:00 PM
TAC_Sisco
Jan 8, 2004 06:33 AM
89 GT
Nov 18, 2003 03:24 PM
MustangGT95
Jul 31, 2003 02:56 AM
