changing heads
Old Nov 13, 2006 | 01:44 PM
hardcore91LX's Avatar
hardcore91LX
Default RE: changing heads
I just saw it was bored over and was thinking 306 I cant see how you are not spinning the tires off the line with 471 horsepower. What is the tranny an auto, I would just be worryed you would split the block with any boost added.
Old Nov 13, 2006 | 01:48 PM
smbikes's Avatar
smbikes
up high its good but dowen low is sucks
it just a bad setup
Old Nov 13, 2006 | 01:52 PM
hardcore91LX
oh so it is a high rpm motor with very little bottem end.
samseed101's Avatar
samseed101
ORIGINAL: smbikes
i think im going to boost[sm=badbadbad.gif]
But my comp is 10:1
so will that hurt?
10:1 is up there, but it won't really hurt. Of couse, if you can drop the compression some that would help you by letting you run more boost.
Old Nov 13, 2006 | 01:58 PM
smbikes's Avatar
smbikes
there ya go , wich sucks
Old Nov 13, 2006 | 02:03 PM
hardcore91LX
then yeah switching over your top end with some matched parts should move your power down the rpm range pretty good. Remember you probally should switch out your cam also when doing that so it matches up to the rest, I would go custom cam also trust me jay will set you up.
Old Nov 13, 2006 | 02:05 PM
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
depnding on which s/c u get it may not help low end... ull what a roots type for low end... twin screw would work too... not a centrifugul tho thots more top end i believe
Old Nov 13, 2006 | 02:44 PM
nmerrill's Avatar
nmerrill
Yeah man, throw a huge twin screw on top of there. Those things are awesome!! I dont know exactly how they work but i think you just bolt your carb to the top of the blower
2007StangV6
Jan 28, 2016 06:09 PM
Luke9222
Oct 22, 2015 11:55 PM
cbird1177711
Sep 2, 2015 04:12 PM
