tranny flush
tranny flush
i'm gonna flush my tranny this weekend and was wondering if royal purple atf was the best stuff to put in it. anybody now of anything better?
[IMG]local://upfiles/52571/A9F4BE0AE7AB4E09BE7F09F46CA9B17A.jpg[/IMG]
RE: tranny flush
PIZZA ROLLS ![8D]
oh um yeah, have a shop use the machine and 16 quarts to flush it. Royal purple is indeed top quality !
Max ATF® is a synthetic, high performance, long life, multipurpose, automatic transmission fluid. It's more oxidation stable than other transmission fluids for a longer fluid life. Max ATF's low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Automatic transmissions generate a great deal of heat and depend on the transmission fluid for cooling and protection. More than 90 percent of all automatic transmission failures are caused by overheating.* A drop of 20°F in fluid temperature can double the life of the transmission.* Max ATF® significantly reduces heat to extend the life of your transmission and is recommended for all automatic transmissions requiring Ford Mercon® or GM Dexron® III transmission fluids. Max ATF® is fully compatible and can be mixed with other automatic transmission fluids; however, for the best results drain or flush the current oil and then fill with Max ATF®. Try Royal Purple® today and Feel the Difference! *Source: Perma Industries Inc.
RE: tranny flush
If you havent done it regularly then alot of shops wont do it anyways. I work at Jiffy Lube as Lower Bay Mechanic and if the trans hasnt been flushed regularly I wont flush it because it always makes the trans have problems. I get people in all day long wanting to flush there trans and they've never done it before and then I ask how many miles on the car and there always like over 100K.
RE: tranny flush
wait a sec..you're going to flush it using royal purple? Man, you must be rich! That's gonna be about $160 for the fliud alone, LoL.
Maybe I'm just cheap, but I'd rather flush it using the generic crap and then when I get home, change the fluid again and then add the royal purple.
RE: tranny flush
about rp beeing the best thing to put in your five speed the answer is yes, But not atf, Royal purple has this stuff called Syncromax, its made specifacly for manuals that call for atf. Thats just what ive read on here and royal purples website.
treesloth
09-28-2015 07:03 AM
