sea foam
Old 11-17-2006, 10:55 PM
PJB
PJB's Avatar
Default RE: sea foam
ORIGINAL: 89GTRed
at least eric actually posted a pic with it! I havent tried the seafoam but i have heard good things about it. If I do try it Ill prolly have to do it at a parking lot cause my neighbors like to call the cops on me for ANYTHING...bastards.
I was going to post a video but there was so little smoke it wasnt worth it.
PJB is offline
Old 11-18-2006, 01:02 AM
vt89gtvert
vt89gtvert's Avatar
I am doing this tommorow and will see if I can;t get some pics and video. My car has 330,000+ miles, so this could be interesting.
vt89gtvert is offline
Old 11-18-2006, 01:43 AM
94gtcoupe
94gtcoupe's Avatar
330000 miles WTF man
ORIGINAL: vt89gtvert
94gtcoupe is offline
Old 11-18-2006, 02:36 AM
Twisted
Twisted's Avatar
Is that relic still running the original motor? Unrebuilt? Be careful, that carbon may be holding your motor together...it may start to melt like a slab of butter, right off the motor mounts.
Twisted is offline
Old 11-18-2006, 02:45 AM
mattdel
mattdel's Avatar
[sm=funnypostabove.gif]
mattdel is offline
Old 11-18-2006, 03:31 AM
vt89gtvert
vt89gtvert's Avatar
I guess I should have prefaced. Same block. I just like saying that cuz it gets peoples attention. I rebuilt the motor at 250,000 not because it was running bad, but I had wreched the car at the time and thought it would be a good idea while the motor was out. went 250,000 and the only thing that went south was the water pump at 200,000. I included a pic for yall.
Old 11-18-2006, 03:47 AM
89GTRed
89GTRed's Avatar
nice car, bad pic[:@]
89GTRed is offline
Old 11-18-2006, 07:44 AM
BlueDemon
BlueDemon's Avatar
I'll probably be adding that stuff to the stang this weekend through the brake booster vaccum line .Then I'm going to put it away for the winter---Damn that sucks[&o]
[IMG]local://upfiles/8760/0B3A692A555340A98D1B1F9167312E80.jpg[/IMG]
BlueDemon is offline
Old 11-18-2006, 08:21 AM
grabbem88
grabbem88's Avatar
it's in your heads guy's...placebo effect
grabbem88 is offline
Old 11-18-2006, 01:36 PM
shaners90lxhatch
shaners90lxhatch's Avatar
Yeah, I agree with grabbem somewhat. Seafoam will remove carbon from your intake valves but it is not the most effective stuff out there. Go to a FLM delaer and ask for PM3 top engine cleaner. D9AZ-19579-BA. The newer cans are blue and the older cans are red & white. Follow the directions on the can, they pretty much sum it up. The hotter the engine is when you do it and the harder you drive it afterwards, the more effective this stuff is. Its a pain in the **** to do it on a 5.0 because you have to suck it through a vac line. Find one that is most centrally located. Hold the RPM's at about 2500 because you are putting liquid in the intake and we all know how much these intakes like liquid....... You don't want to hydrolock it but trust me. I have used it for years on all my vehicles, foregin and domestic and it is the only thing that really really works. Change your oil afterward too as it may dilute it. Obviously dumping a $5 can from autozone in your gas tank is easier, but are you more concerned with efforts or results?
shaners90lxhatch is offline
Quick Reply: sea foam
