Removing engine/dissasembly?
Old Nov 18, 2006 | 04:42 AM
BAM614's Avatar
BAM614
Default Removing engine/dissasembly?
Is it easier to disasemble the top half of the engine out of the car or is it not worth the trouble of pulling the motor? Basically I need to pull the heads/cam/rockers/headers off my car to swap them out and was wondering if I should pull the engine to do it or do most people do it in car? Also, any tips or advice would be appreciated. Starting tomorrow.
Thanks
Old Nov 18, 2006 | 11:50 AM
Sacmo's Avatar
Sacmo
Default RE: Removing engine/dissasembly?
Leave it in... Realy don't need to pull it unless your getting into the block... If your doing long tube headers you will need to undo the motor and tranny mounts and lift the engine to put those in...
Old Nov 18, 2006 | 12:43 PM
88MustangGX's Avatar
88MustangGX
i dont know about the cam though... i am taking my engine apart right now. i just have to take off the passenger side head's then i'm gonna yank the motor. The manifolds were easy to get off. Fuel rails were a bit of a b1tch to get off, but otherwise it's just about loosening bolts. The cam however would be easier if you yank the motor i would say. But i'm sure it could be done. here check this out..
http://www.allfordmustangs.com/techa...intakeswap.pdf
that should clear things up for you. good luck
Old Nov 18, 2006 | 01:08 PM
r.barn's Avatar
r.barn
leave it in
Old Nov 18, 2006 | 01:33 PM
ryan_89_mustang's Avatar
ryan_89_mustang
The cam will come out if you move the rad out of the way
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
wawagner82
Sep 13, 2015 09:02 AM
