v6 to 5.0
v6 to 5.0
hey guys....i have a 95 5.0 and im currently rebuilding the engine....the car has been hit in the front and it looks like it might be a pain in the bass to fix....i found a v6 car down the road without the engine....it is in a lot better shape than the car i have now....i was wondering if i got that car,what all would i have to replace to make it able to run with this engine....
when the engine is done it will be like this.....
302
cobra intake
gt-40 heads
trick flow stage 1 cam
forged pistons
24lb injectors
75mm tb
70mm maf
mac shorty headers
1.7 rockers
smog pump eliminator
ud pulleys
n20
and its a 5speed if that matters.
302
cobra intake
gt-40 heads
forged pistons
24lb injectors
75mm tb
70mm maf
mac shorty headers
1.7 rockers
ud pulleys
n20
RE: v6 to 5.0
Computer and all the harnesses, thats a given so youll need to gut the dash. The K-member should work but will probaly need different motor mounts. Im not sure about the trans-member or the driveshaft. Youll need a new rear as the v6 uses the 7.5. Add the V8 brakes and suspension of course and you should be on your way.
RE: v6 to 5.0
I'm in the process of doing that right now. i got a wrecked parts car that had the entire drive train and i'm basically just putting my body on the gt guts. I don't think you have to gut the dash though, the computer is under the dash on the passenger side but i think all the wiring inside the dash can stay the same. you will need a new gauge cluster though.
RE: v6 to 5.0
ORIGINAL: Blckstng93
RE: v6 to 5.0
yeah the parts from the 95 are fine...its just the outer part of the engine bay that is bent all to hells.....i just didnt know what all i needed to changed..and ill probably do a complete interior swap also because the interior in the 95 looks as good as the interior in my 03....
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
