if your squirting 100 jets on a mostly stock stang the stock pump and injectors is fine, you should get a new pump though simply cuz the one you have is really old, so might as well bump to a 190.
a 190 + 24# injectors will support 400 hp no probs
go with a 255, u cant out grow it that easily and its not that much more money. Just another thing u would have to change later if you went with the 190
an AFPR is NOT a replacement for getting a fuel pump. the fuel pump is rated on how much fuel it can push out in an hour. the fuel pressure regulator adjusts how much fuel actually goes in. so you arent going to make a 190lph pump as much fuel as a 255.
