Really weird problem
Old Nov 27, 2006 | 09:03 PM
JABES's Avatar
JABES
Default RE: Really weird problem
with the negative cable off the batter cannot charge the coil its an incomplete circuit therefore if it died you would know that you had a bad alternator
Old Nov 27, 2006 | 09:05 PM
mattdel's Avatar
mattdel
even though the coil is grounded through the TFI, and the alt is grounded to the engine....
Old Nov 27, 2006 | 09:19 PM
JABES's Avatar
JABES
im talkin about the battery directly charging the coil it wont work without the cable
Old Nov 27, 2006 | 09:24 PM
mattdel's Avatar
mattdel
right so that would be a battery issue not alt.
Old Nov 27, 2006 | 09:27 PM
JABES's Avatar
JABES
i was saying if there was a problem with the alternator and you disconnect the battery you have disconnect what is charging the coil which makes no spark and your engine will die thats only for an alternator problem
Old Nov 27, 2006 | 09:32 PM
mattdel's Avatar
mattdel
theoretically disconnecting either cable on a system that is grounded to the battery will kill it. but on the EEC system, disconnecting the negative cable will not kill the car. most alternator's put out 10 volts +/- when they begin to die. although this is considered a discharge, it is still a postive 10 volts after the battery has drained that far.
Old Nov 27, 2006 | 09:51 PM
mustnglvr's Avatar
mustnglvr
Or you could just use a volt meter
Old Nov 27, 2006 | 11:02 PM
ddeaton66's Avatar
ddeaton66
+1 on the volt meter, so much easier.
I have had similar problems twice before in the past. I found both times that some wires had goten too close to heat (heads or exhaust) and would intermitantly ground out. That's the only thing I can think that fits all your symptons.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
