Trans cooler
Old Nov 27, 2006 | 03:36 PM
86 GT 5.0's Avatar
86 GT 5.0
Default Trans cooler
Do you need a trans cooler?? I would like to spray later on(dont know if that matters or not). Transmission is an AOD with a shifkit...
Old Nov 27, 2006 | 04:46 PM
ttoppedaerocoupe's Avatar
ttoppedaerocoupe
Default RE: Trans cooler
do you mean separate from your radiator?
Old Nov 27, 2006 | 06:10 PM
86 GT 5.0's Avatar
86 GT 5.0
yes, seperate from my radiator
Old Nov 27, 2006 | 08:13 PM
fourfivefour's Avatar
fourfivefour
If you are running a stall converter you should run an external trans cooler. If still running the stock converter than the cooler in the radiator is sufficient.
Old Nov 27, 2006 | 08:16 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: fourfivefour
I personally would prefer to NOT have my transmission fluid running into my radiator... radiator gets hot, your fluid heats up.... I would much rather get an aftermarket cooler and mount it out in front of the radiator in open air to assist in cooling the fluid... wether your on a stock converter or not...
I'll be doing that with my OIL cooler, im gonna run a bigger pan and an upgraded cooler... low fluid temps is a nice thing
Old Nov 27, 2006 | 08:17 PM
BlackLX's Avatar
BlackLX
Even with a stock aod I would get one. I still need to get one myself.
Old Nov 27, 2006 | 09:06 PM
89GTRagtop's Avatar
89GTRagtop
With a shift kit I would suggest you get a trans cooler, they are not too expensive, or hard to install. I have one and have not had any problems
Old Nov 28, 2006 | 12:10 AM
86 GT 5.0's Avatar
86 GT 5.0
Thanks guys, looks like i'll be getting one...
Old Nov 28, 2006 | 01:05 AM
OneFine89Mustang's Avatar
OneFine89Mustang
you dont need it but it is highly recommended
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
