power adder FI q's
power adder FI q's
Generally speaking, when adding a blower or turbo to a motor, still using FI, would speed density or mass air be better, ive heard supporting sides of both.... but it seems to me after doing some reading on FI, that SD would be the choice here... ?
RE: power adder FI q's
I say MAF. MAF is more accurate period. When it comes to stoichiometry of a forced induction motor - very small inaccuracies can have very significant consequences. I am willing to bet that you will not find a speed density system on any factory turbo/supercharged vehicle after the mid to late 80's. MAF all the way. It can obviously be done with speed density but I think the benefits of a MAF controlled system are obvious.
with forced induction many people use sd, only w/ a gm map sensor. the system is slightly different from the stock sd system, but this allows you to tune based on boost. w/ a maf setup the tuner has no clue what the boost pressure is. and you say sd is more accurate, maybe without tuning, but when you are tuning the car you can get it just as accurate as a maf car.
ORIGINAL: 88blackgt
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
