gears again...sorry
RE: gears again...sorry
SO why do people actually change tio 3.73 gears???
I have 3.73 gears but they were on when I got the car.
I mean just for .40 of a sec? I mean these gears seem to tear up my gas milege... not to mention the rmp's it runs at on the highway... i mean a constant 2.5 grand cant be good for engine life can it????
Let me know!!! Thanks!!!!
Well since most people with 3.73s either dont drive on the highway too much, or dont care about gas mileage...that doesnt seem to be a problem. And what other mod can u do that will give you 4 tenths for 180 bucks?
2.5k RPMS that doesnt seem too high. then again i drive 120 on the freeway. my main concern is my top end, i dont want to me limited to much on my top end. i know i will loose some, but the question is how much?
ORIGINAL: Aliate X
Roundman, what mods do you have on your stang?
https://mustangforums.com/m_205780/mpage_3/tm.htm
ORIGINAL: luckythirteen13
with 3.55 in 4th what speed would the car be going at 4k rpm's?
with 3.73 in 4th wha speed would the car be going at 4k rpm's?
ORIGINAL: Big5.0.13.7sec.
The single biggest reason people get bad mileage is their heavy right foot! You can have the performance and fun of a V-8 with low gears and still get decent mileage as long as you don't drive it all the time like you're going down the drag strip!
Yeah I agree once you pointed that out 2500 is not to high seeing it's a V-8. Im not really saying I am trying to get a gas efficent car, obviously thats not going to happen. But i commute to school, just trying to get the best I can. I dont drive like im at drag strip everyday!LOL.
The tires I have are 275 40 17. In the rear and 245 40 17 in the front. im not sure i understand what you mean by shorter than stock tires.
Thanks!!!!!
Thanks!!!!!
Well the bigger the radius on a tire, the farther it will go in one turn. to find your speed with any gears u take the RPMs, multiply it by sixty to get it per hour. Then divide it by ur gear ratio to find how many times per hour your tire is spinning. Then multiply that by the distance it goes in one turn, which is the circumfrence (dont know how to spell that), or pi x diameter. That will give you it in inches, then just convert it over to miles(divide by 63360), to get your miles per hour. Hope i explained that correctly.
roundman, i have stock sized tires. id go check for sure but im school and my car parked about a half mile from where i am.
will i still be able to do 100mph without blowing the motor apart?
