cold starts
Old Dec 10, 2006 | 01:46 PM
ROTTITANK's Avatar
ROTTITANK
Default cold starts
Now that the colder weather is upon us. The stang is harder to start. It cranks but doest start intill about the 6th or7th try.Once its running it fine.Its just getting it to start.I just dropped a new battery in last week. Thinking that was the problem. Once its running for five min. or so.I can turn it off and it will start right up the first time. I have no idea..wtf?
Old Dec 10, 2006 | 01:53 PM
watson30's Avatar
watson30
Default RE: cold starts
new battery?
Old Dec 10, 2006 | 01:54 PM
AdderMk2's Avatar
AdderMk2
Banned
prime it first.... you may be geting some slush in the fuel lines.... drop a bottle of dry-gas in it
Old Dec 10, 2006 | 03:36 PM
06YellowGT's Avatar
06YellowGT
Measure the battery voltage if you can. OCV should be over 12.6.
If the vehicle cranks for 6 or 7 times, sounds to me like the battery is performming OK, and the problem may be elsewhere.
As a battery engineer, my favorite line to use is "if the vehicle cranks, my part is not the problem!"
Old Dec 10, 2006 | 03:39 PM
Ninety5five0's Avatar
Ninety5five0
Take it up to a parts store that tests your chargins system, they'll tell you if it is good or not. I think alot of cars start harder when its cold, atleast mine do.....
Old Dec 10, 2006 | 03:53 PM
06YellowGT's Avatar
06YellowGT
Just a (maybe boring) FYI.... cars are harder to start in the cold for two main reasons.
1) It is harder to turn over, because oil is thicker when cold, and a whole bunch of other similar items
and
2) The battery is not capable of performing as well. As the battery is a chemical reaction, the chemical reaction "slows down" when it is cold.
good luck!
Old Dec 10, 2006 | 08:07 PM
ROTTITANK's Avatar
ROTTITANK
Old Dec 10, 2006 | 08:33 PM
93 LX FiveO's Avatar
93 LX FiveO
bad ground
bad coil
no fuel pressure (bad pump most likely)
just some things to consider
goodluck
Old Dec 11, 2006 | 12:35 PM
ROTTITANK's Avatar
ROTTITANK
^^ got 40lbs
StalkerGT
Sep 25, 2015 02:41 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 1, 2015 08:16 PM
