larger injectors and MAF
I am looking to buy 24lb injectors and the matching 73mm MAF.
I am running a stock 5.0L with just a fenderwell intake and 2.5 exhaust. wil add E303 cam and 1.7 rockers this summer.
is there any advantage to going to larger injectors, and would it require any other mods to make them work correctly?
and is there any performance gains by the larger injectors?
RE: larger injectors and MAF
you'll get alittle bit more performance out of the bigger injectors and mass air the only other mod i would suggest would be an adjustable fuel pressure regulator and a pressure gauge for the line, and bump the timing up
ORIGINAL: LondonGT
However, you will see some power from a good MAF upgrade.
Since you can stick with stock injectors, the best option is to swap in a MAF/MAS from a 94-95 Mustang.
All you need to do this swap is a MAF tube and sensor from a 94-95 Mustang (either v8 or v6 will work), and an adapter flange which can be found on the internet.
This is the most accurate MAF available for your setup.
jason
jwog666
12-27-2021 08:09 PM
