Nitrous question
i do not know much about nitrous and had a couple of questions...first, what is needed, besides the kit, to safetly run nitrous? second, would nitrous be safe for my car (mods in sig and i have around 110,000 miles and i would only use it at the track and i only go in the summer)?and finally, what is the best kit to buy? if i do buy a kit it will be a stage 1 kit and i will only want an extra 75 hp.
your gonna want to get a BBK 225 fuel pump if you don't already have one. Adjustible regulator. you could spray 150 shot with no problem if your fuel setup is good. Just make sure when you spray it your pressure don't drop. NOS, NX,or Edlebrock makes the best kits right now.
110,000 miles and ya wanna run juice ..lol good luck with dependability after a cpl shots///better make sure timing is right,let us know after a few shot,how ya towed the car home..lolfresh rebuild id say itll last longer,but you have to much wear on rings...
I had a similar question guys (don't mean to steal thread) I have new fuel pump and fuel regulator already when I hook up nitrous do I need to adjust timing differntly for when I run spray and when I run motor?
Also wet or dry for fuel injected?
