Nitrous question
ORIGINAL: ford91mustang
what is a window swith and what does it do???how much do they cost??
this has been asked a few times, so i will answer. ANY nitrous info i've read says that u can run 10* timing up to the 150shot. anything above that will require timing to be taken out. MAKE sure you get a window switch cause we all make mistakes and mis shift!
so i am planning on buying the NOS Stage 1 EFI system 1986-1995 5.0...i will also buy a adjustable fuel pressure regulator, 255 fuel pump and a window switch....does anyone know how much $ installation would cost??????
It takes about 2-3 hours to install the nitrous kit. Another2-3 hours for the fuel pump and regulator and about 1 hour for the window switch.
Figure $30-40 a hour so about $200.00
All this stuff can be installed with basic hand tools and a half *** monkey,but a lift would make the fuel pump install so much easier.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
