351 block
RE: 351 block
special roller lifters.. or i think you can drill and tap it for the spider tray but thats not recommended, b/c i believe you will lose oil pressure or something like that, honestly the best thing to do is just hold out and get a roller block or just use a custom ground flat tappet cam
RE: 351 block
http://store.summitracing.com/partde...p;autoview=sku
if you have a 92 and up block than you are ok and all you need to do for the 92-92 is tap it for the spider tray, all blocks b4 92 had shorter lifter bores thats why you lose oil if you use the spider tray on them
http://www.freewebs.com/vristang/fox351wswapfaq.htm
This link has alot of useful info to help you out
Matt's 95 Stang
10-05-2015 07:16 AM
