Welding
RE: Welding
Think that you are asking about .030 or .023 wire. I'd use the .030 but I would try and find out what gauges the stuff is that I'm trying to weld togather and do some test/set-up BEFORE you weld the car.
If you have a choice of gas I would use 'Stargon' it's 25% Argon, 75% CO2.
Make sure that you clean the area to be welded as clean as clean can be as there is apt to be undercoat, road tar, road kill and so on under there.
Take your time, make some small tacks first so that you can get the best possible fit-up as the wire is for filler material, not filling in material.
Have fun........
Have fun........
09-17-2015 07:57 PM
cardsrus1
19
09-15-2015 08:37 AM
