rocker arm ratio
Old Jan 3, 2007 | 11:24 AM
pizzarolls's Avatar
pizzarolls
Default rocker arm ratio
i've got a b-303 cam and windsor heads......anyone now what the best ratio rocker arm i need......and where to get em. and feel free to let me now your setup....brands and setup.
Old Jan 3, 2007 | 11:52 AM
pizzarolls's Avatar
pizzarolls
Default RE: rocker arm ratio
WOOOO!!!! slow down with all the info....
pizzarolls's Avatar
pizzarolls
1.6 or 1.7......tell me!!!
Old Jan 3, 2007 | 11:55 AM
Jay Meagher's Avatar
Jay Meagher
1.72's will work well and put valve lift at .516 at the valve tip... minus deflection. If you are using worn out valve springs they will also drive you into valve float sooner.
Old Jan 3, 2007 | 11:58 AM
15austin's Avatar
15austin
It is up to you, 1.6 lift will be480 with 1.7 the lift will be 512 (same as an f cam). I think if you plan on running the b cam forever then 1.7s, but if you ever plan on going a different cam 1.6. I once had the bcam/1.7, but had so sell and then buy 1.6s for the xcam.
Old Jan 3, 2007 | 02:13 PM
pizzarolls's Avatar
pizzarolls
wheres the cheapest? guide me like im blind!
Old Jan 3, 2007 | 02:19 PM
15austin's Avatar
15austin
I got my 1.7s and 1.6s out of summit.
Sixer4Life
Oct 12, 2015 04:26 AM
UrS4
Oct 3, 2015 06:23 AM
UrS4
Sep 30, 2015 10:13 AM
uedlose
Sep 30, 2015 08:01 AM
Sixer4Life
Sep 28, 2015 07:05 AM
