Traction-Lock rebuild..
Old Jan 5, 2007 | 05:26 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: Traction-Lock rebuild..
When rebuilding the trac-lok... you dont have to take the carrier out of the diff. All you need to get the job done is a soft mallet, brass punch and some vise grips.
Jack up the back end of the car and disassemble the brakes. remove the diff cover.
Push the axles in as far as they will go, remove the C-clips from the end of the axles
Remove the diff pin locking screw
using the soft mallet and bronze punch, strike the diff pin through the carrier, only hit it out a little bit, or you wont be able to turn the carrier.
pull the diff pin out of the carrier... this might take some time, but try not to damage it in any way.
Using the vice grips, pull out the S-spring. It has a bit of stored energy, this is why I recommend using vice-grips... it will keep it from springing out and hitting you in the EYE!!!
slowly rotate the spider gears in the diff until you can slide them out one by one. once you have the top gears out, the side gears will also come out...
behind the side gears are the clutch packs.
Old Jan 5, 2007 | 05:32 PM
7upedition's Avatar
7upedition
ummm huh , and alternate clutch discs everyother for a tighter bite... rather than two then one clutch...
lClClCl vs. llCllCll
Old Jan 5, 2007 | 05:42 PM
dimebag's Avatar
dimebag
^thats basically what the link says, but goes more in depth
oldawgnewtrikz
Members Mustangs
15
Oct 1, 2021 06:49 AM
MustangDudley
Dec 2, 2014 01:54 PM
-rpark-
Apr 1, 2012 02:59 PM
narib2008
SVT Forums
Jun 6, 2011 06:27 PM
boogerschnot
Aug 12, 2007 10:48 PM
