GAS LEAK HELP!!
Old Jan 4, 2007 | 11:12 PM
blk89lx's Avatar
blk89lx
Default GAS LEAK HELP!!
ok well my friend was driving behind me and he noticed when i make a left turn gas spills out of the tank. and in my driveway there is a lil puddle under where the filler neck goes into the tank. could it be that rubber gromment the seals the filler neck and the tank. its had to tell exactly where its coming from becasue a good part of the tank is convered in gas. any help would be great thanks
Old Jan 4, 2007 | 11:14 PM
00limited7's Avatar
00limited7
Default RE: GAS LEAK HELP!!
That's probably it or it could be the "O" ring for the pump install.
Old Jan 5, 2007 | 02:28 AM
Li0nHart's Avatar
Li0nHart
might as well drop the tank and have a look. I wouldn't trust that driving around...imagine if it gets on your exhaust...probably coming from where the filler and breather tube enter the tank. fuel filter is also located up under there in front of the tank...could be leaking there as well.
Old Jan 5, 2007 | 02:50 AM
JustalittleLX's Avatar
JustalittleLX
yea i would just drop the tank and replace every seal under there. i mean while ur under there might as well. saves u a trip next time some other seal starts to leak. but at the same time "if it aight broke dont fix it" ur choice i guess
Old Jan 5, 2007 | 04:23 AM
SSKiller's Avatar
SSKiller
ORIGINAL: blk89lx
Yes it IS the gromment that the filler neck goes into.............mine did the same thing.
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Sixer4Life
Oct 12, 2015 04:26 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
