flat tap it vs. roller cam?
RE: flat tap it vs. roller cam?
ORIGINAL: 351w8bang93stang
whats the real differances and can any older block be converted to a roller cam?
First off, its Flat Tappet, they have flat lifters as the name describes and generally dont stay open as long, and pollers have roller ends, and broader lobes allowing for longer valve duration, ive also heard that if the lobe angles on the flat tappet are too steep they can be notched by the lifters. I see no reason that a non roller couldnt be converted, but it requires taking everything off short of the heads...
ORIGINAL: FuzzyDiceRule
i would like to suggest that if you are building a block up, you should look into build a 351w more benificial and its cost around the same. read this it might change your mind http://www.freewebs.com/vristang/fox351wswapfaq.htmif you havent changed your mind to answer your question about converting a non roller to a roller the easiest way is to use these http://store.summitracing.com/partde...p;autoview=skuand they're not exactly cheap
I just read your signature and it seems you are familar with the 351w so disregard this post unless you still find it useful
ORIGINAL: 89Ford
holy crap that cost too much for lifters!!!im going to make sure i get a roller cam motor to start with. i have a older flat tappet 302 but it broke off that funny half moon deal on the bottom of the cylinder wall, and im not sure its usable now, but it just needs a piston and rod i geuss
ORIGINAL: 89Ford
That part is the only thing you need to convert a flat tappet to a roller?
well you need to the cam too i suppose, and mayber different rods, but those are rollers and the are connected so you dont neec the dog bone and spider tray i think. when you buy the linked rollers you have to get the retro fit ones
jwog666
12-27-2021 08:09 PM
