Cam Questions
Old 09-25-2004, 01:36 PM
  #21
vfast
I ♥ Acer
vfast's Avatar
Default RE: Cam Questions
ok[sm=icon_ladiesman.gif]
vfast is offline
Old 09-25-2004, 04:38 PM
  #22
NegadivOne
NegadivOne's Avatar
Thanks for all the replys everyone, that answered most of my questions. So I was searching through the old posts and they all said buy new gaskets. Is that just for the water pump and valve covers? Also, should my ignition timing stay at 10 BTDC with the new cam?
NegadivOne is offline
Old 09-25-2004, 04:44 PM
  #23
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
You'll need water pump, timing cover, valve cover, and an intake gasket at least. You should change the timing chain & gears too while your there, its cheap and your already there - at least change the chain.
mdvaldosta is offline
  #24
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Oh yea, bump the timing anytime - just have a tank of gas with premium fuel at the time.
Old 09-25-2004, 07:29 PM
  #25
NegadivOne
NegadivOne's Avatar
K cool thanks. Ill have to get those gaskets. Im also thinking this might be a good time to put on a 1/2" intake spacer.
Old 09-26-2004, 11:57 AM
  #26
roundman
roundman's Avatar
just make sure you check the existing hood clearance first before you buy something that makes you need a cowl hood that you were planning on buying!
roundman is offline
Old 12-08-2004, 03:54 AM
  #27
91hatchgt
91hatchgt's Avatar
I know this is an old post, but it had some good info in it, and I thought I would bring it back up with a new question. If the stock cam in the gt only goes up to about 4k RPM, why does the tach go all the way to 5950RPM? I understand after mods that 5950 will be like nothing, but at 4k RPM I feel like I am just beginning to hear my engine growl, then it drops off. What are the major changes to increase your RPM range? Intake? Heads? Cam?
91hatchgt is offline
Old 12-08-2004, 04:03 AM
  #28
nemethjames1
nemethjames1's Avatar
with my stock cam i notice its power band opens up around 2800, all the way til like 5
nemethjames1 is offline
Old 12-08-2004, 04:27 AM
  #29
Dbeck002
I ♥ Acer
Dbeck002's Avatar
my power band drops off pretty quick right after 4600 RPM. i never rev to 5 because im afraid she'll blow up lol..
Dbeck002 is offline
Old 12-08-2004, 04:34 AM
  #30
nemethjames1
on your site tho it shows your tach at 5
Quick Reply: Cam Questions
