will it fit?!?!?!?
ORIGINAL: rmodel65
yes but id just swap the brakes and axles imho it would be a lot simpler
pee lus 1
ORIGINAL: AdderMk2
unfortunatly, swapping a SN-95 rear into you car will also widen your stance by about 1.5" SO any wheels you have that "barely stick out" will now have a pronounced protrusion from the wheel well. It would be worth your time to purchase aftermarket components instead of using factory SN-95 parts. I.E. 31 spline axles, and a new differential!
ORIGINAL: rmodel65
no i mean keep the stock fox axles instead of having to pull the pinion and resteeing the depth etc just unbolt the axles since ud begoing that deep into it anyway just pull the brakes instead of the diff lots easier imho
jwog666
Dec 27, 2021 08:09 PM
BeatnikFink
Oct 1, 2015 08:00 PM
