My Coupe is lower on the passenger side than the drivers side......
My car is a lot lower on the passenger side than the drivers side. It has Eibach pro-kit springs. The pass. side looks normal but the the drivers sides looks higher than it should for a lowered car. What would be causing this.
I was thinking maybe the shocks...struts????????? HELP!!!! Its annoying!!!
RE: My Coupe is lower on the passenger side than the drivers side......
Are your shocks adjustable? Some are adjusted higher to put more traction to the rear wheels for drag racing, maybe it's configured for this setup? Maybe something isn't seated correctly? I'm not sure, but check the adjustment thing if there is one.
check the spring mounting to be sure the pigtail end of the springs is seated properly in the control arm up front and at the rear on both side of the car. up front there is a little hole in the spring cup on the bottom of the control arm, the end of the spring is supposed to be just back of this hole.
dude i had the same f-ing problem. i coodnt figure out y but then i got new struts and shocks and now my car sits real nice, try that it shood work
ORIGINAL: mdvaldosta
Do you have a fat girlfriend? No need to lie... its a technical question
if that's the case, then it should level up when he gets in it and I wouldn't worry about it, certainly not enough to buy new struts and shocks unless I knew they were worn out.
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
