Trick Flow or ecam Wich is better?
Old 01-06-2007, 11:11 PM
gearbanger
gearbanger's Avatar
Default Trick Flow or ecam Wich is better?
A guy that i know is always talking crap about my car and how his is better and blah blah blah.... hes just got a a stage 1 trickflow cam....and he was sayin that the cam that i got (Ecam) Is Crap.. wich do you guy's think is better? and acoording to the a** the Stage one makes more power? thanks i just want to here others oppinion..
gearbanger is offline
Old 01-07-2007, 12:27 AM
XSRACINGGT
XSRACINGGT's Avatar
Default RE: Trick Flow or ecam Wich is better?
I would think they make pretty much the same power. Not too far off as far as specs for each of them is concerned. I am runninga stage 2 TFS cam in my motor and saw about 10-13 HP more at the wheels than the average TFS setup on Foxes. Lots more torque too, like 25 ft/lbs. I have 1.6 RR though. Not the 1.7's. I would stick with the e-cam, and not waste the money on the stage 1. Its alot of trouble for a gamble on gains. Unless you just like blowing money and time.
XSRACINGGT is offline
Old 01-07-2007, 12:34 AM
grabbem88
grabbem88's Avatar
they are both crap
grabbem88 is offline
Old 01-07-2007, 12:35 AM
live4motocross11
live4motocross11's Avatar
y is the tfs1 cam a risk, thats what ppl r suggesting for me?
live4motocross11 is offline
Old 01-07-2007, 01:17 AM
8URWS6
8URWS6's Avatar
I have the TF stange 1 cam and I love it, I have never experienced the E-cam but I have heard it. The TF stage 1 cam sounds alot more aggressive in my opinion.
I THINK WE NEED TO GET ADDER INVOLVED..... Hey ADDER!!!!!
8URWS6 is offline
Old 01-07-2007, 01:40 AM
gearbanger
gearbanger's Avatar
ORIGINAL: grabbem88
they are both crap
yes i know they are not the greatest...
Old 01-07-2007, 01:44 AM
gearbanger
gearbanger's Avatar
ORIGINAL: XSRACINGGT
oh no im nopt going to get the stage one if where to go get a cam i would go with some thing bigger that a stage 1.....
Old 01-07-2007, 04:02 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 8URWS6
Why do I always have to get dragged into this ****......
E-cam specs... .498/.498 lift with 1.6 rockers 224°/224° duration at .050 valve lift
TFS1 specs.... .498/.510 lift with 1.6 rockers 221°/225° duration at .050 valve lift
I would say the determining factor as to which cam would make better power would come down to the duration difference seen with the two cams on intake... the TFS1 cam leaves the intake valve open for less time at the same lift, thereby limiting the amount of air that will enter the cylinder. However.. The TFS1 can will make some of that back with its higher lift and ever so slightly longer duration on the exhaust valve.
I dont think you would see a very big difference between the two cams. I would have to further analyze the LSA and cam events timing to give you a better idea... but.. I would still take the Steeda #19 with 1.7 ratio rockers over both of those
AdderMk2 is offline
Old 01-07-2007, 04:29 AM
uni_uni
uni_uni's Avatar
adder its because you wear that fancy tech certified badge
uni_uni is offline
Old 01-07-2007, 04:58 AM
ooticamitica
ooticamitica's Avatar
lol adder knows his stuff!
ooticamitica is offline
10-26-2015 05:01 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
jaiidutch
09-14-2015 10:29 AM
09-10-2015 08:39 PM
Gabe_mlcc
09-07-2015 11:56 PM
Quick Reply: Trick Flow or ecam Wich is better?
