2 front suspension questions/
RE: 2 front suspension questions/
Turn the wheel to get the tie-rod back on spindle.
You may or may not need to use the spacers that came with the 90/10's.
Yep, it's possible to put the springs in upside down.
Check the torque on the upper strut mount like somebody said. If they are loose or the rubber donut thing has come out there will be a 'clunking' sound as you jounce the car up/down.
BTW, aren't those springs fun?
haha oh these springs are a blasttt! ill check the bolts on the strut. where is the rubber spacing thing located? and on the springs there is writing on them that says moroso and the part number. i put the springs in so you could read the name without it being upside down.
Matt's 95 Stang
10-05-2015 07:16 AM
