painting interior
#22
RE: painting interior
dude dont waste your time with anything else go to your local paint shop and get what 88bluegt said SEM landau black vinyl dye. just be sure to take your time to prep and besure to use wax and grease remover prior to washing with soap and water. to sand just use agray scuff pad and make sure you get the whole panel sanded, let dry and use bulldog adhesion promoter let sit for 5-10min and shoot light coats of color and you have a sick looking interior. I even painted the carpet pieces and the headliner with many light coats but looks good. thats the only pic i got of my interior now.
[IMG]local://upfiles/10407/3F3E3522919641359C319CC294CB5232.jpg[/IMG]
#24
This is what a black-painted interior looks like after a while.
http://forums.stangnet.com/attachmen...p;d=1170396038
Yeah! Looks great!!!!
#25
you want to clear coat that stuff with water based outdoor stuff. i know a friend who used the fusion stuff on his cavi and it got all sticky in the summer because it sat outside all the time. then after he cleared it, look awesome!! and only use water if the paint your using is water based and if its laquer or oil based use that base for a clear
#26
I cleaned mine with windex and used Krylon Fusion black paint. Works great as long as it's plastic. For the door panels and armrests though, I would suggest ordering them from 50resto.com The door panels are only like 100 bucks a pair. Not sure about the armrests though.
#27
ORIGINAL: wythors
#28
The one experience I had with paintingsome interior pieces,we used that black bumper paint from autozone. The finishmatched the other plastic pieces that were originally black. It was that matte plastic look not like the tacky lookin gloss finish you'll get from the other black paint.
#29
Man dont be knuckle heads and use any type of rattle can paint. I do body work and paint, use a vynil dye and paint hard, flexible plastics and even carpet. It will look original and can be armorall'dor what ever shine you want to put on....
treesloth
09-28-2015 07:03 AM
