Procharger questions.....
There are some things I would like to know about the Procharger. What kind of oil does it take and where can I pick some up at? Is the drain plug and fill plug easy to find? Thanks.
RE: Procharger questions.....
It takes actual procharger oil. It takes 6 oz in most cases. All it is, is a synthetic motor oil. It's fairly expensive for what it is, cuz it's like 40 bucks for 3 bottles online. You change it every 6000 miles. There is a screw with a flat head end on it on the top of the charger. Just use a really wide screwdriver cuz the screw will seize up where the charger gets hot. It will have a little dipstick so that you can check it. Here is the website where i ordered mine. http://www.exoticperformanceplus.com....html?item=688. Good luck
Dragonus18
09-09-2015 01:21 AM
Black_GT_02
08-20-2015 01:26 PM
