swapping
RE: swapping
With enough $ you can do anything. With enough brains you wouldn't even begin to try to make a swap like that work. At best do it on a V8 SHO to keep the swap in v8 to v8 territory but even then it's stupid because the V8 SHO motor will run circles around a stock 5.0. I say you are foolish to attempt such a frankenstein job
RE: swapping
If I had enough time/money/fabrication skills I would do something like that. Anything is possible if you want it to be. I just dont think you are going to be able to get much help over the net because its not a common swap.... at all.
Matt's 95 Stang
10-05-2015 07:16 AM
