Wind noise and driver's door alignment...
Old 01-19-2007, 06:25 AM
easter9053
easter9053's Avatar
Default Wind noise and driver's door alignment...
I will be attempting soon to see what's wrong with my driver's door. I have to slam it hard in order to keep it closed fully. When it's closed fully a small portion of the driver's side glass rest on the frame of the back window metal causing a shiny area on the metal where it's been closed so many times against it.Sometimes when I slam the door hard in my convertible the driver's side window seems to come out of alignment also and sits uneven in the window. So after slamming the door for the 2nd time while driving, I have to lower the driver's side window a tad then let it up again to get it back aligned. I also have some wind noise. (I know there is wind noise in my 93 conv) but this wind noise is pretty obvious and I believe can be fixed. The weatherstripping on the driver's side looks to be intact in most places but I would rather try to see why my driver's door isn't aligning up right 1st. I've heard of replacing the driver's door hinges. Have any of you guys replaced your door hinges? (Also my driver's door hinges doesn't seem to have nothing to stop it from fully swinging out. Is there a safety mechanism to have it slow down the full swing like most cars have or is this the way Mustangs are?)
easter9053 is offline
Old 01-19-2007, 09:31 AM
verter2
verter2's Avatar
Default RE: Wind noise and driver's door alignment...
Check out 50resto.com They have everything you need to redo your door hardware. Sounds like your striker may need to be replaced. My 91 vert doors are a little off now (not flush w/ body), the hinges are fine, I think it's all in the striker/locking mechanism. Good Luck
verter2 is offline
Old 01-19-2007, 09:53 AM
easter9053
easter9053's Avatar
I guess that hasn't bothered you so much as to replace the striker in your car?
Old 01-19-2007, 11:28 AM
93must
93must's Avatar
If the top part of your door is hitting the back window then you are correct you need to replace the hinges! It probably wouldnt hurt to replace the latch and striker also.
93must is offline
Old 01-19-2007, 01:54 PM
Monstang
Monstang's Avatar
Also check your hinge pins. 50resto.com has everything you need!
Monstang is offline
bjdutch2005
03-24-2017 03:38 AM
ccdguy
09-19-2015 05:20 PM
09-08-2015 11:50 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Wind noise and driver's door alignment...
