MM Road and Track kit...???
i was looking at MM website and i saw this MM road and trick package here is what it includes:
[ul][*]MM Strut Tower Brace[*]MM 4-Point K-Member Brace[*]MM Full Length Subframe Connectors[*]MM Panhard Bar with Aluminum Rod[*]MM Heavy-duty Rear Lower Control Arms[*]MM Road & Track Springs[*]Bilstein HD front struts[*]Bilstein HD rear shocks[*]MM Caster/Camber Plates[*]MM Urethane Pinion Snubber[*]Front spring isolators[*]Rear spring isolators[*]Solid Steering Shaft[*]MM Aluminum Rack Bushings, center drilled[*]Front Swaybar bushings[*]Front Swaybar end link bushing kit[*]Front control arm bushings, urethane[/ul]what do u all think?? good??? bad??? not enough there?? more than need ethier?? i will be using like is says on the road a lot on the track with im ready to run it... what do u all say??
RE: MM Road and Track kit...???
When you say track are you talking about the drag strip or the road race coarse. That setup is for road racing and street driving. If your going to road race or just looking for good handling sounds like a good kit.
I have the mm full length subframes and they are going to be a PITA to install. They don't line up at all and I'm going to have to bend them right to make them fit.
i would drag on occation but mostly for fun.. i want somethan that handles well... 90% of the drive i do in it will be on the street... i want something that handles well but will also OK at hte track... its not a drag only car.. its a fun car i drive when im not working or at school... mostly a weekend car nemore
Well your not going to hook at all at the track with that setup, to damn stiff up front and to stiff of springs. If you want better handling but more drag strip friendly setup keep stock springs, get a set of rear control arms, full length subframes, get a strut tower brace (can be removed in 5 minutes before going to the track). You'd be suprised how much better you car will handle on the street with a much cheaper setup.
what about MM sport box??
The Sport Box includes the following parts: [ul][*]MM Strut Tower Brace (select Black or Chrome finish)[*]MM 4-Point K-Member Brace[*]MM Standard Subrame Connectors (bare steel)[*]MM Panhard Bar with Aluminum Rod[*]H&R Sport Springs[*]Tokico Premium Performance Front Struts[*]Tokico Premium Performance Rear Shocks[*]MM Caster/Camber Plates (select Black or Chrome finish)[*]MM Urethane Pinion Snubber[*]Urethane Front Spring Isolators[*]Urethane Rear Spring Isolators[*]Urethane Steering-Rack Bushings[*]Urethane Front Swaybar Bushings[*]Front Swaybar End-link Bushing Kit[/ul]like i said i was something that can handle well... like a porsche... but i what it to be able to hook at the track or on the street if i wanna do a lil drag...
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
