changed alot, still wont idle right
Old 01-24-2007, 10:26 PM
brundz
brundz's Avatar
Default changed alot, still wont idle right
i put in a brand new idle control valve and tps sensor and set it, checked for vacuum leaks but couldn't find any and it still wont idle right. it has a map sensor otherwise i woulda cleaned the maf. any other ideas. it like chugs when decelerating at low speeds and jumps sometimes at idle.
brundz is offline
Old 01-24-2007, 10:31 PM
mattdel
mattdel's Avatar
Default RE: changed alot, still wont idle right
auto or 5spd?
mattdel is offline
Old 01-24-2007, 10:32 PM
brundz
brundz's Avatar
auto unfortunetly
brundz is offline
Old 01-24-2007, 10:34 PM
mattdel
mattdel's Avatar
now when you say 'jumps at idle' do you mean the idle is going up and down, or the car is trying to jump.
mattdel is offline
Old 01-24-2007, 10:35 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
ok
have you checked the fuel pressure?
are you getting a good current to the plugs?
2 kwik is offline
Old 01-24-2007, 10:37 PM
brundz
brundz's Avatar
haha it revs up 200rpms randomly at idle and just like chugs along as it slows down. i didn't check the fuel pressure. i was also thinkin maybe a clogged fuel filter
brundz is offline
Old 01-24-2007, 10:39 PM
mattdel
mattdel's Avatar
i'd start with with fuel pressure. sounds like a tiny leak in the regulator.
mattdel is offline
Old 01-24-2007, 10:40 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
could be..I wish I could hear it I might be of better help
2 kwik is offline
brundz
brundz's Avatar
aright thats where i'm heading next...never touched a fuel regulator before. any hints to throw my way as to where its located and how to test or adjust?
brundz is offline
Old 01-24-2007, 10:41 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
it's on the fuel rail
2 kwik is offline
2007StangV6
01-28-2016 06:09 PM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: changed alot, still wont idle right
