oil pump
Old Jan 28, 2007 | 11:34 PM
mattdel's Avatar
mattdel
Default oil pump
well i have the notorious pressure drop at idle, so i wanna do something about it. i wanna do a high flow pump, and all that jazz, but i remember a while back reading a thread where someone had posted a downside to high volume oil pumps, and i was wondering if anyone knew, cuz i cant find the thread.
Old Jan 29, 2007 | 12:08 AM
mattdel's Avatar
mattdel
Default RE: oil pump
ttt
90Lxstanger's Avatar
90Lxstanger
this wasnt it was it?
I've heard that with a high volume pump you can suck all the oil out of the sump and lose pressure. A lot of people actually run stock or stock replacement pumps. Just put in a new stock replacement when you do rebuild or even have the engine out. I've also seen some high volume pumps twist the oil pump driveshaft and snap it off. Stock should do just fine.
Also found that- high vol. pump twist the pump driveshaft...
Old Jan 29, 2007 | 12:34 AM
BOOK EM DANO's Avatar
BOOK EM DANO
My recent mustang purchase came with the notorious oil pressure drop at idle, and a really cool knock knock knock. It also came with a junk yard 302HO & a bunch of new parts, one of which was a new melling high volume oil pump. Upon installing the Melling HV oil pump on the junk yard motor I.........(learned the hard way) it had a clearence problem. It is a little taller than the stock. (yes, I measured & don't remember the specs) Anyway, when I torqued the oil pan down, after I was done I saw a split in the corner of the pan.......It was the pump! I had to beat out the crease & weld the pan and gring down the corner bolt of the pump & all is fine now. I guess I got lucky with the junk yard motor as it runs great & the factory oil pressure gauge is Always 5/8 of the way up. The previous owner put a newer style (Ford) pan & pick-up tube on recently before I bought it. Hope this helps.
Old Jan 29, 2007 | 12:46 AM
mattdel's Avatar
mattdel
thanks for that response BOOKEM, i was thinking about a 7qt pan during the pump install, you've now sealed that deal.
90lxstanger: i think the remedy to that would be a high volume oil driveshaft.
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
wraith777
Sep 28, 2015 10:49 AM
mrappe
Sep 26, 2015 10:16 AM
