Head bolt broke off and leaking antifreeze
Old 02-01-2007, 08:24 PM
nit4gudtime
nit4gudtime's Avatar
Default Head bolt broke off and leaking antifreeze
I just discovered i have a head bolt head that has broke off flush with the head. Its leaking antifreeze from around the bolt. Do you think if i remove broken bolt and replace it and put some teflon tape on threads it will seal up? I think the bolt goes into a water jacket thats why its seaping. On the driver side. Thanks for any feedback
nit4gudtime is offline
Old 02-01-2007, 08:27 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Default RE: Head bolt broke off and leaking antifreeze
Leaking or not I'd still replace that bolt. You may have a leaky head gasket because of that. How long has it been broken / leaking?
WhiteFoxGT is offline
Old 02-01-2007, 08:29 PM
92hatchLX
92hatchLX's Avatar
Is it one of the bolts that are near the exhaust manifolds or one of the bolts that are near the rockers?
92hatchLX is offline
Old 02-01-2007, 08:40 PM
AdderMk2
Banned
AdderMk2's Avatar
if it is actually a head bolt thats broken... you better change that head gasket, because it will never seal properly again
AdderMk2 is offline
Old 02-01-2007, 08:44 PM
92hatchLX
92hatchLX's Avatar
ORIGINAL: AdderMk2
+1
Old 02-01-2007, 09:11 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
so what are you really asking? I can tell you how to do a temp fix without removing head but, if you want to keep car replacing it should be done
2 kwik is offline
Old 02-01-2007, 09:54 PM
nit4gudtime
Not sure how long it has been broke. Its by the exhaust manifold. I know its not a permenant fix but would it stop the leak for a little bit. Its not a everyday driver. Just wanna stop problem for the moment till i can order some x303 heads
Old 02-01-2007, 10:05 PM
nit4gudtime
It juststarted leaking. Its not spraying but it is seaping. Curious if i can put another head bolt in it with some teflon on the bolt to hold it together for a little while. Thanks
Old 02-02-2007, 11:07 AM
nit4gudtime
bump
Old 02-19-2007, 07:08 PM
nit4gudtime
Screw it. I'm building a top end for this thing. Heads, intake, Cam, etc........... Aint no sense in tryin to patch something together for a bit. Just spend the money!!! I'll post new hop-ups when finished and the end result.
Quick Reply: Head bolt broke off and leaking antifreeze
